5 Machine Operation Functions You Might Be Overlooking
Chris Heeg
Okuma lathes and machining centers come equipped with a wide variety of functions—sometimes so many that it can be overwhelming. While you may not need every function, the following are a few that could significantly improve the way you use your machine.
  • NC Panel Lock
    This key switch is intended to restrict viewing and editing access to your machine’s parameters. After getting your machine set up and running, put the NC Panel Lock in the ‘lock’ position and take the key out. This could save an accidental crash.
  • Machine Lock
    The Machine Lock function is a great way to test run your machine’s programming. Turn on Machine Lock mode to be sure your axes and spindles won’t move, then run the program as if the machine were moving to check the program over.
  • Single Block
    Move through a program one line at a time using the Single Block function. This will help you see where your tool is at different times during the machining process, plus, it can help you figure out where to point the coolant nozzles.
  • Release/Neutral
    After you turn your machine on manual mode, this function will allow the spindle to freely rotate so that you can check the condition of your machining center’s tool insert or lathe’s chuck jaws.
  • Zero/Off Position on Pulse Handle
    If you have the machine in manual mode and don’t want to accidentally move an axis, turning the pulse handle to the ‘off’ position will keep a mistake from causing damage to a part or fixture.
Whether you choose to use one or all five, the above functions can truly help improve your machining process. If you need help getting started, or maybe have more questions about functionality in relation to your machine, contact your local Okuma distributor.
